OK - it now works fairly consistently (about 95%) on the second flashgun I bought. Thank you for the feedback
I have to press it really hard. Fingernail? No, it would break the fingernail off
Pretty obviously this is a bad batch with a manufacturing c**ckup and their final inspection never tests the flashgun buttons.
I had some inconclusive (I guess google translated) comms with one of the amazon.co.uk vendors, in China apparently, saying they have never heard of it before. Well, they would say that, anyway.
The flashgun works impressively otherwise, with the -602 radio trigger from the same firm. For the money, one can't fault it. I have an old Metz one (was £300 new) which never worked properly other than fully manual and this one is a lot better.
The burst flash feature would be fun for special effects (freeze-frame stuff of somebody running, etc) although it clearly doesn't work as configured e.g. if you set up 20 flashes at 10Hz you do not get a 2 second long burst of flashes; you get something like 5 flashes. In fact anything more than about 5-10 flashes doesn't get delivered in the right number, regardless of the power setting. Obviously the gun is not going to deliver 20 flashes at max power at 10Hz (that would take an awful lot of power to recharge it) but even testing it at 1/128 power, it still doesn't seem to do more than about 10. It might be another bug, but one is rarely going to use that feature for anything real.
Quote: When using P-TTL, you can put the on-camera flash into controller mode. It will then output only an inconsequential amount of light.
Sorry to ask a stupid question, but am I right in saying this is purely to
trigger the flash i.e. there is no intensity control by the camera?
I know that if I buy the Pentax flash (they do two models, both pricey) and put it in the camera's shoe (there is no other way to couple it AFAIK) then you get fully TTL intensity control. I also "know" that 3rd parties like Metz make more or less compatible flashguns which do the same thing - with varying degrees of success/compatibility.
But I don't think the K3 has the capability to do TTL with a
remotely located flash. Obviously it can't do it via radio (there is no transmitter in the K3) and I don't think it has the Nikon/Canon feature whereby it communicates with a remote flash using the on-camera flash.
