10-22-2014, 07:56 AM   #1
cactus v6/YN560-11 problem
I have three cactus v6 triggers, and using a YN560-11 flash, and pentax af-360 fgz. The problem is that I cannot consitantly get the YN to fire from the trigger. It will always fire if i hit the manualabutton on the front of the trigger, but no matter what settings i use on either flash or trigger, it will pretty much just fire when it feels like it. No problem with the pentax flash, and it matters not which V6 units i use.
I do not understabd why it fires all the time if triggered manually, but then wont fire from the trigger even though the trigger is properly synched, and works fine with the other flash. Ideas?
10-22-2014, 08:08 AM   #2
Class A's Avatar
QuoteOriginally posted by dogzilla Quote
Have you tried a firmware upgrade for the V6?
Make sure to select the "manual" flash profile when using the YN560-II. I remember some issues with certain flash models that were not fast enough to recognise the V6's trigger impulse. A firmware update solved this issue.
P.S.: If you are running an old firmware version, you could try to use the Nikon SB-24 profile. This solved the issue for another user who couldn't fire their YN560-II.
10-22-2014, 08:30 AM   #3
You are a genius! switching to sb 24 profile did the trick; I tell you, this wireless thing is making me
long for pc cables, lol!
cactus, cactus v6/yn560-11, fire, flash, lighting, pentax, photo studio, strobist, trigger, v6
Cactus V6 Flash Compatibility -- Profiling Successes and Failures Class A Accessory and Memory Articles 106 05-15-2022 04:28 PM
Cactus V6 Radio Trigger Review Class A Flashes, Lighting, and Studio 244 04-03-2017 03:38 AM
Cactus V6 Storm Chaser Troubleshooting and Beginner Help 7 10-16-2014 11:04 PM
Cactus v6 help dogzilla Flashes, Lighting, and Studio 13 05-26-2014 10:57 PM
Cactus V6 Radio Trigger has Arrived Class A Flashes, Lighting, and Studio 28 05-14-2014 08:19 PM
All times are GMT -7. The time now is 02:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
