Originally posted by manntax 1) The batteries on either transmiter/receivers or the flash itself were weak and communication either was disturbed or flash simply misfired because was not fully charged
In this case, the green confirmation light on the transmitter would light up, but not the one on the receiver. That's why I stated my assumption about the transmitter already not being triggered by the camera.
Addressing the issue obviously depends on at what stage the trigger signal is lost.
Originally posted by manntax 2) The communication between the camera and transmitter was disturbed due to transmitter not being tightened in the hot shoe or due to some dirt/grease being on the hot shoe.
In this case, the green confirmation light on the transmitter would not come on.
If this is the case then potentially using the flash directly on the camera won't be 100% reliable either. Alternatively, contact problems could only manifest themselves with the transmitter or there is indeed an issue with the signal duration.
Originally posted by manntax With some flashes and in *certain* configuration of position of the camera with transmitter on it and the receiver with flash on it - the communication between transmitter and receiver is BLOCKED by the flash itself !
Hmmh, I don't want rule out that you are right, but given the enormous range the V5 and V6 have, there should be a lot of reserve left for the signal to be attenuated by an obstacle, even if it potentially causes radio interference, such as a flash.
Is it possible that these misfires in macro situations were caused by the transmitter being too close to a receiver?
If you go below the minimum distance, which depends on the rotation of the V5/V6 against each other, then the signal is too strong and communication won't work anymore.
For this reason, the V6 has a "SHORT" option for a working range setting. Once this is engaged it is almost impossible to provoke misfires in macro shoots or other scenarios where the transmitter may come into very close proximity to a receiver.
