11-04-2014, 07:21 AM   #1
External flash
Is any one of the Pentax external (or camera mounted) flash units to be recommended over any other for building interior and group shots? Reviewers seem disappointed with build quality on some models.
BG
11-04-2014, 07:49 AM   #2
enoeske's Avatar
QuoteOriginally posted by Bill G Quote
BG
Building interior: You'll want a bunch of cheap manual flashes with radio triggers.
Group Shots: (I'm guessing people?) You'll want a high power studio strobe with some modifiers like a large softbox.
11-04-2014, 09:36 AM   #3
Dark Underlord
AquaDome's Avatar
If you're looking to stick with a Pentax branded flash, your choices are AF360FGZ II and AF540FGZ II (and their earlier counterparts without the II designation).
The 540 is more powerful than the 360, and more expensive. Otherwise, their features are similar.
The newer FGZ II models feature rotating swivel head, LED video/modeling light, and WR sealing. Older versions do not swivel around; they only pivot up and down.
I have the older AF360FGZ and find it does pretty much everything I need it to do, on camera and off.
There are lots of inexpensive manual and/or slave flashes out there. I recommend getting one of these two Pentax branded flashes for its feature compatibilities on and off your camera, then adding on slave flashes and other equipment (adapters, sync cables, wireless triggers) as necessary. A light stand with reflector and diffuser (soft box) are quite useful.
There are a couple of brands that claim compatibility with Pentax P-TTL and other features. I have not tried any of them.
11-04-2014, 10:55 AM   #4
Otis Memorial Pentaxian
photolady95's Avatar
QuoteOriginally posted by AquaDome Quote
Not so, the AF540FGZ has swivel, the AF360FGZ does not.
PENTAX AF 540FGZ reviews - Pentax Camera Accessory Review Database
Yes, tilt and swivel
And thread moved to proper area of forum.
11-04-2014, 11:01 AM   #5
danielblues's Avatar
I found a cheap Metz 58 af-1 that worked like a champ after a firmware upgrade on a k30
Metz Mecablitz 58 AF-1 Digital - Pentax P-TTL Flash Comparison
This is a good starting point:
The Definitive Guide - Pentax P-TTL Flash Comparison
daniel
11-04-2014, 11:02 AM   #6
Dark Underlord
AquaDome's Avatar
QuoteOriginally posted by photolady95 Quote
There you go - that makes the 540FGZ the best option if you don't want to pay current prices for the current II version.. Lack of a swivel is the only complaint I've ever had about the 360FGZ, so I use it off-camera mostly.
11-04-2014, 11:12 AM   #7
KEH has the AF540FGZ for less than $220. KEH is a good place to buy used Pentax gear. They have excellent customer service and a hugh warranty, 6 months.
11-07-2014, 04:18 PM   #8
Oldbayrunner's Avatar
+1... I bought two of them from Keh and they work like a charm.
Another downside with the Af 360fgz (not the ll) is that is doesn't have the disable auto shut off feature which can make off camera use more of a pain than the AF 540fgz.
flash, k-30, k-50, pentax k30, pentax k50
K01 External Flash? Ray Pulley Pentax K-01 12 08-28-2014 11:36 PM
Diffuser for external flash: advice? enoxatnep Flashes, Lighting, and Studio 13 03-17-2014 08:49 AM
K-r: built-in flash stopped working after using external flash wedge Troubleshooting and Beginner Help 7 01-12-2014 07:57 PM
*ist D external flash Fishchip Troubleshooting and Beginner Help 6 11-22-2013 08:32 PM
external flash problem chickenphone Pentax K-01 20 02-05-2013 08:32 AM
All times are GMT -7. The time now is 01:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
