Originally posted by BrianR It's not so important to me that I'd be willing to carry an entirely different system to get super high syncs (or switch systems for half or even a full stop), but if one of those old Nikon bodies with the magical shutters were available in a k-mount I'd be tempted to drop a couple hundred and run with the 6mp ccd when the situation warrants it. There are a number of 'advanced' P&S that can sync at high speeds, they're tempting too but I haven't brought myself to it yet
You could always get a PZ-1(p). That camera has a 1/250th sync speed and supports K-mount. Unfortunately, it doesn't support HSS, so once you are at max sync, that's all you get. Still, it's a fantastic camera in it's own right.
In the quest for higher sync speed, I almost bought a Q7. I figured, "hey, a leaf shutter" that will almost justify the indignity of owning a Q. Ahem, unfortunately, the R&D folks at Pentax missed another golden opportunity and it turns out that you can only take advantage of the 1/2000th sync speed through the pop-up flash. If you use the hotshoe, you are limited to 1/250th
Anyone who has ever tried to sync a flash in bright sunlight via optical slaves will understand my frustration. It's unreliable at best, and at worst, impossible, really just depends on the situation.
But realistic you say? Well the original Canon 1D had a kevlar or titanium shutter with a 1/500th sync speed, and a maximum shutter speed of 1/16000th. Obviously it's possible, though I'm sure it's a bit more expensive.
There are actually two benefits to having a faster sync speed, even when dealing with HSS. The obvious one is for every stop of "real" sync speed, one extra stop of ambient light is removed from the equation, making your flashgun effectively one stop more powerful at balancing the ambient light.
The other benefit take a little imagination to visualize. At speeds above the max sync speed, the second shutter curtain begins to close before the first curtain completely opens. This is of course why flash manufacturers resort to HSS which causes the flash to pulse continuously for the duration of the shutter curtains' travel (In the case of Pentax, for 1/180th of a second) . The individual shutter curtains always traverse the distance across the sensor, no matter what shutter speed (30 seconds all the way to 1/8000th of a second), at the same velocity. As the shutter speed increases, the curtains at any one point in time will occupy more and more of the sensor real estate, or one might think of it as an ever-narrowing slit that travels across the sensor. Now,
here is the key, with a higher max sync speed, the size of the slit will be wider at any given shutter speed. So the slit on the Canon 1D will be twice the width of the slit on the Nikon D800, and probably 3 times wider than the Pentax K3 (because of the cropped sensor) all at say 1/1000th. What this means is more of the light from the flash actually reaches the sensor, and less bounces off the shutter curtains, reducing the penalty for crossing the sync speed barrier. Also, since the curtains are in motion for less time, in theory the flashgun could put a bit more power into each pulse, further reducing the penalty, but that's assuming that the increase in power wouldn't cause overheating.
Would people pay more for an extra stop of sync speed? Well, I'm asked to pay for video, a feature that I have no intention of ever using, yet video seems to get all the attention these days. Pentax have neglected their flash system for years, and it, along with AF and yes, video, are all thing that need to improve if the brand is to be taken seriously by professionals.
