11-21-2014, 04:11 AM   #1
Does Godox V850 do HSS with Pentax?
The title should say it all. Is this possible? I think not, but i'm asking to get to know.
The trigger that I bought with the flash (Godox FT-16s) does not support HSS as far as I understand.
Is there a work around this? Will a trigger that support Canon or Nikon HSS do the trick?
11-21-2014, 04:56 AM - 1 Like   #2
LensBeginner's Avatar
I fear not...
https://www.pentaxforums.com/forums/125-flashes-lighting-studio/180003-high-s...ml#post2915784
Someone else talked about Cactus V6 triggers, but they'd only dumb-trigger the flash, you'd need an intelligent flash for that...
There's a very informative and complete review from the same user (bdery) here:
https://www.pentaxforums.com/reviews/godox-ving-v850-system/introduction.html
which I believe would be an interesting read.
11-21-2014, 07:59 AM   #3
I'm not sure if bdery 100% up to date with every feature of the flashes.
You don't need a intelligent flash to do HSS. I know there re people doing HSS with the dumb Godox AD180/360 flashes with third part triggers (Yongnou and others) with Canon and Nikon. The intelligens is in the trigger, not the flash as far as I know.
V850 and AD180/360 shares the same FT-16 trigger. So I thought maybe ...
11-21-2014, 08:42 AM   #4
I think aokatec triggers can do hss with pentax. But its not as easy as the flex-ttl5 pocket wizards for canons.
11-21-2014, 09:43 AM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by Fototim Quote
With any luck bdery will weigh in on this discussion.
11-21-2014, 01:55 PM   #6
maxfield_photo's Avatar
I'd say there is about a 98% possibility that using the Godox Canon transmitter will not give you HSS functionality when fired from atop a Pentax camera. I say this because a) Pentax cameras do not speak the proprietary Canon digital TTL protocol, and b) the pins on the hotshoe don't line up. Godox will have accomplished an engineering miracle if they managed to get this trick to work. The V850 does seem to be a great little workhorse of a speed light though.
The Cactus V6 transmitter won't allow you to do real HSS either, but there is way to specify a delay in milliseconds that might allow you to accomplish a trick that Pocket Wizard calls "Hypersyncing". Basically the optical slave on the V6 would pick up the light from the preflash from a camera-mounted HSS master, then wait a certain number of milliseconds and fire the Godox (ideally at full power) prior to the first curtain's movement. At full power, most speedlights have a long tail to the flash that can last, oh about 1/90th of a second. The trick would be to find the right delay so that the peak of the flash happens before the first curtain begins to open, and you are left with a more-or-less flat flash tail. To the camera's sensor this would effectively appear to be a continuous source of light. Unfortunately, like real HSS, you end up wasting a lot of the flashgun's power. This trick isn't Godox specific, it has the potential to work with any speedlight, the slower and the more powerful, the better.
11-21-2014, 04:48 PM   #7
Class A's Avatar
Unfortunately, with a Pentax camera you absolutely need an HSS-capable flash, otherwise the camera will not produce a trigger signal once you exceed the sync-speed.
There are triggers for Canon and Nikon that pretend to be HSS-capable flashes but no such triggers exist for Pentax yet.
Hence, whether one uses the Aokatec triggers or the V6, one always needs one HSS-capable flash connected to the camera.
The Cactus RF-60 has a manual HSS mode so that one at least does not need off-camera HSS-capable flashes for real off-camera HSS (which has advantages over the HyperSync technique maxfield_photo described).
The Godox V850 also has an HSS mode but I do not know whether it can be engaged manually or whether it only works with the Canon-specific Godox Cells-II trigger.
11-21-2014, 09:48 PM   #8
QuoteOriginally posted by maxfield_photo Quote
Yes, the Godox V850 must be paired with the Cells II trigger to support HSS and the Cells II is available only in Canon mount.
---------- Post added 11-21-14 at 08:51 PM ----------
The Godox product page says essentially that:
GODOX PHOTO EQUIPMENT CO.,LTD
"High Speed Sync Triggering Provided. Up to 1/8000 second according to the camera. A high speed trigger e.g. Godox Cells II is a must."
Whether another brand will work is not know.
11-24-2014, 07:54 AM - 1 Like   #9
bdery's Avatar
Here I am
Yep.
Indeed. In order to trigger a V850 to fire in HSS, the Cells II transmitter must tell the flash to do so. In order for the transmitter to send the right command, it needs to receive that command on its contact pins. Without using tricks and cascading triggers (which might or might not be possible, I doubt it but I don't know) only a Canon camera has the right contacts and the right protocols to tell the Cells II to send the HSS command.
Now if there is a device available on the market that receive a basic "fire" command and converts it to a "fire with HSS using this particular set of exposure values" the Cells II could then be mounted on that device and tell the V850 to fire accordingly.
11-24-2014, 07:43 PM   #10
Class A's Avatar
Without using tricks and cascading triggers (which might or might not be possible, I doubt it but I don't know)...
There are no such tricks as the only device that is currently able to persuade a Pentax DSLR to fire a flash beyond the sync-speed is an HSS-capable P-TTL flash.
At least the Cactus V6 or the Cactus RF60 can use their optical triggers to either use the main flash (no manual timing required but only works up until 1/2000s or so) or the pre-flash (requires manual setting of a delay timer) to fire HSS bursts.
camera, canon, cells, flash, godox, godox v850, hss, ii, lighting, photo studio, steve, strobist, support, trigger, v850, v850 do hss
Anyone using the Godox V850? jbsg02 Flashes, Lighting, and Studio 77 03-19-2016 01:15 AM
Godox V850 Review Adam Flashes, Lighting, and Studio 8 09-24-2014 05:06 AM
Godox Ving V850 para Pentax jorge2014 General Talk 3 07-11-2014 06:54 AM
Does this seems correct? HSS BBear Photographic Technique 35 02-08-2010 11:59 PM
Any way to do HSS with radio trigger? Light_Horseman Pentax Camera and Field Accessories 6 01-04-2010 02:49 PM
All times are GMT -7. The time now is 04:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
