Originally posted by Zapper I just got a manual flash, and of course (I guess) it has a zoom funtion. Is this only relevant when you use it on camera and pointing forwards? Does it have any function when you use it off-camera and in a softbox?
In advance, thanks for any help.
Manual zoom flashes outside straight forward should be used as you would a weak snoot as it behaves exactly the same allowing you to control direction and radius of the light emitted.
Straight forward it should be used to give a higher GN for tele type lens ensureing the beam radius still exceeds the lens width. (aps-c,ff etc etc)
