Originally posted by hll i know pentax af 540 has wireless feature.
must i use the pop up flash to synchronize them? i am a k10d user and use my sunpak's with ebay triggers.
is it possible to synchronize k10d with any flash (which has wireless feature like 540 or sigma 530) without using the built-in flash???
may you elaborate about the wireless feature of the flashs like 540 or sigma 530??? are they usable with ebay triggers????
thanks
The 540 has 2 wireless modes:
1. Pentax Wireless: You must use the pop up flash, or a 360/540 flash that is on the camera, to trigger the off camera flash. However the pop up flash does not need to affect the exposure, if can be set in the custom settings to only trigger the flash using preflash, not actually fire during the exposure.
2. Optical slave: Any burst of light will trigger the flash. The pop up flash can not be used to trigger it in this mode, because the p-ttl preflash from the pop up flash will trigger the 540 too early. But if you use a radio trigger to trigger a sunpak flash as you say, then the sunpak flash will be in manual mode and you can use that flash to trigger the 540.
You switch between the two wireless modes by pressing and holding the light button and then toggeling with the center of the adjustment dial.
