Originally posted by ivanvernon P-TTL standard settings on the AF-360FGZ works great on my K-3, but very poorly on the K-20, with huge under exposures, almost a black screen. Settings on the flash unit are exactly the same, and settings on the two cameras are the same--green mode.
Wondering if anyone has experienced this, or has any ideas I can explore. BTW, the lens being used is the Sigma 30 f 1.4.
fwiw, I use the 360 occasionally on both those bodies and never noticed an exposure difference. However my usage could very well be quite different from yours as it typically for macro or a fill when shooting outside. Good luck tracking it down.
EDIT - reread you post and noticed the green mode. I have never used the flash in green mode.
