12-13-2014, 05:33 PM   #1
Will using canon flash?
It used to be the case if you used different brand flashes would damage your camera. Don't want to have an expensive accident. I have ex580 flash for my canon dslr. Will using it on my k-3 hurt my new camera?
12-13-2014, 05:46 PM - 1 Like   #2
QuoteOriginally posted by Rob wright Quote
I doubt you would have a problem. I use my triopo Nikon on my k5 with no problem you will just have to figure out your manual settings since it doesn't no how to talk to the Pentax.
12-13-2014, 06:08 PM   #3
Digitalis's Avatar
Contemporary canon flashes use a 5.5v trigger signal, well within the capabilities of a pentax DSLR. However do not expect any TTL flash control, Only pentax specific flashes can provide this.
12-13-2014, 06:46 PM   #4
Yep...and take care to never mount the Canon flash backwards on your camera. The flash reportedly has a pin that will drop into a hole on the Pentax camera resulting in a semi-permanent attachment.
OTOH, wouldn't it be easier to simply pick up a cheap speedlight? You would get the same functionality.
12-13-2014, 09:15 PM   #5
Loyal Site Supportaxian
jbondo's Avatar
Caution! ALL modern TTL Canon flashes have 5 pins, and whether you mount it forwards or backwards there is a danger that the one pin that Pentax mounts leave blank will cause a jam. Now some flashes, like my Nissin Di866 have triangle shaped pins which are not susceptible to jamming. Examine your pins carefully. Don't use it if your flash has pins that are not well radiused or otherwise jam proof.
12-14-2014, 08:50 AM   #6
Cool, thanks for the replies. I'll check my pins. I'm going to get As pentax flash, probably next year. Just can't afford after being the new body and lens. Helpful advice here.
12-17-2014, 07:16 AM   #7
awaldram's Avatar
You can also get some weird behavior as not all cameras use center pin firing for x-ttl
It conceivable you could get random firing (not synced) and also incorrect levels even if your flash supports auto/maual
camera, canon, flash, lighting, photo studio, strobist
For Sale - Sold: REDUCED Canon 5D classic + 50mm lens + canon grip + flash + 2x batteries robwill Sold Items 4 02-25-2014 09:39 PM
Using a Canon 430 EXII Flash? Franky2step Pentax K-5 4 12-27-2011 09:26 AM
will k5 work with wireless canon flash Bear Flashes, Lighting, and Studio 3 10-24-2011 05:47 PM
Using a Canon footed flash on a Pentax.. arbib Flashes, Lighting, and Studio 3 05-13-2010 11:48 AM
Using Canon 40D with wireless flash barondla Non-Pentax Cameras: Canon, Nikon, etc. 4 12-06-2009 05:56 PM
All times are GMT -7. The time now is 05:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
