12-30-2014, 09:36 AM   #1
Trey45's Avatar
AF 540FGZ and AF 540FGZ ii size comparison?
If I were to order a set of diffusers for an AF 540FGZ will they fit the AF 540FGZ ii flash? These are the plastic cup type diffusers that are flash specific, not the one size fits most type of diffuser.
As long as I'm asking, will diffusers for the Yongnuo YN560-II or Canon EX 430 II fit the AF 540FGZ ii?
I have just ordered the AF540FGZ ii flash from B&H, it will arrive Friday. B&H does not yet have diffusers for the ii version and the fellow I ordered from was unable to tell me if they are the same size. Would any of you be able to shed some light (pun intended) on the matter?
12-30-2014, 11:19 AM   #2
Otis Memorial Pentaxian
photolady95's Avatar
PentaxForums reviews gives size of each unit. Read here:
Older AF540FGZ
And AF540FGZ ll
Hope this helps!
12-30-2014, 11:27 AM   #3
Trey45's Avatar
If I am reading the dimensions right, it does not appear that the two flashes are the same size. Thanks for the links! Very helpful
12-30-2014, 11:50 AM   #4
You're welcome! Btw, a lot of us make our own diffusers. Check out the Do it yourself archives here.
12-30-2014, 11:56 AM   #5
Trey45's Avatar
Thanks I will! I have a set of "one size fits most" gels that I can use for the new flash, but those plastic cups are so easy to work with. Since there's not a cup for the new flash available I may end up making something. Heading to the archives now
12-30-2014, 12:01 PM   #6
aleonx3's Avatar
I have seen the new 540FGZ II in Japan while I bought the 360FGZ II, the flash heads are different (smaller). So, the old diffuser you had on the 540FGZ will not work. I have been searching for similar diffuser for 360FGZ II, as I have the old 360 and OMNI bounce. I don't use the diffuser any more, and I just bounce it off to the ceiling and side wall. The LED lamp at the base of the flash helps immensely; and don't find a need for a diffuser.
12-30-2014, 12:02 PM   #7
Just to help a bit more, here is the link to the archives, list in the forum as Pentax Articles forum.
Do-It-Yourself - PentaxForums.com
12-30-2014, 12:08 PM   #8
Trey45's Avatar
Thanks again! Very helpful forum you have here.
12-30-2014, 01:14 PM   #9
Brooke Meyer
Guest
QuoteOriginally posted by Trey45 Quote
Instead of the plastic diffusers, you might consider the Black Foamie Thing .
I posted about it today here: https://www.pentaxforums.com/forums/32-digital-processing-software-printing/2...ml#post3097567
12-30-2014, 01:20 PM   #10
Trey45's Avatar
Great idea! I will certainly try it
12-30-2014, 08:57 PM   #11
Harbor digital says that the Metz af-50 accessories work with a thin filler on one edge.
To quote:
At this time we do not make a custom adapter for the new 540FGZ II but we do
have an existing adapter that can work.
To use the existing adapter you will need to apply the Velcro that we
provide inside of the adapter on one side to achieve a proper fit.
Other customers have used the modified adapter and have informed us that it
fits well.
The adapter to order would be for the Metz 50AF.
I use their flash extender and am waiting for my AF 540FGZII to arrive.
12-30-2014, 09:44 PM   #12
crewl1's Avatar
Here are pictures of the two side by side.
https://www.pentaxforums.com/forums/125-flashes-lighting-studio/241786-540-fg...vs-540-v1.html
01-30-2015, 12:24 PM   #13
Trey45's Avatar
Crewl your link was very helpful, thank you.
02-14-2015, 02:52 PM   #14
GeneV's Avatar
Yes, I had no idea the new one was so much smaller.
540fgz, 540fgz and af, 540fgz ii size, af, af 540fgz ii, diffusers, flash, ii, size, tripod, type
Flash: AF-360FGZ II vs. AF-540FGZ (original) slowdive101 Flashes, Lighting, and Studio 11 02-24-2018 03:25 AM
For Sale - Sold: Pentax AF-540FGZ and Sigma EF-530DG SUPER (flashes) - x2 reduced kp0c Sold Items 7 12-24-2014 06:13 PM
Trigger voltages of AF 540FGZ, AF 360FGZ and AF 200FG ??? GerryL Pentax Camera and Field Accessories 26 07-12-2009 05:58 AM
K20D and AF-540FGZ???? thomps6s Pentax Camera and Field Accessories 5 09-30-2008 09:03 AM
Quick unscientific AF-360FGZ and AF-540FGZ comparison shots Edvinas Pentax Camera and Field Accessories 6 02-22-2008 05:12 PM
All times are GMT -7. The time now is 01:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
