Originally posted by trishytee I have a rather small room in which I have my rather small studio. With white background I have no problems. With the black background I do have problems. This is that when I try to light my subject I get too much light on the back drop. Of course if I put the subject further away from the back drop, then went into the opposite room, I guess the problem would be solved. That is not an option though.
I have very old multi blitz which give me low or high light. One of the draw backs with the Pentax is the fixed shutter speed on flash. If I could shoot faster speeds I might get rid of some of the falling light. I can't up the f stop as then any 'noise'is highlighted. The only place I get any real help is on ths forum so ...help.
today I was advised to aim the lights at me, and use a reflector to direct the light onto the subject. Hmmm, a good way to be blinded it seems to me. So I await the valued opinion from you wise folk.
thanks, Trish
You need to be very careful and exacting about light control when shooting in a small space with reflective surfaces. The good news is it can be done -- I do it regularly -- but the bad news, possibly, is that you will have to spend some money. You need to add things like black cards, or curtains (I use both foamcore and cheap IKEA curtains), softboxes with eggcrates, grids and/or snoots (not snots
You can line your walls with the curtains (just taped up is fine) or black foamcore (or black painted board of some sort) to avoid reflected light hitting your background. And by using grids / eggcrates in your softboxes you will force the light to only hit your subject and not the background.
Here's an example lighting test I did in my smallish office. White walls and ceiling, shiny hardwood floor, shooting in a space of about 11x11 feet. For this shot of my test mannequin I used a black backdrop, hung black IKEA curtains to either side. The single light source is an AF540FGZ flash inside a Westcott Apollo Strip softbox with 40 degree grid attached. Shot is pretty much right out of camera.
