Originally posted by slowhands95128 Could we use a radio remote trio (say, three Cactus V5s) to work around this?
Your idea works with the Cactus V6 (and/or the Cactus RF60), but not with the V5 or any other trigger I know.
The reason is that even if you set the camera to manual focus, etc. its shutter lag will be way too long. The flashes will have fired already by the time the camera starts opening the shutter.
The V6 has a "delay" option, however, allowing you to delay the firing of the flashes. You'd have to set the delay to match the shutter lag of the camera. The latter may not always be 100% the same if you take several quick shots in succession and there is respective processing going on in the background, yet when using flashes at full power to make this technique work, this probably won't be a problem.
If you are using RF60s as off-camera flashes then you can set the delay on them instead of on the V6 receivers. The advantage of using RF60s would be that you could use true HSS (i.e. a long flash burst) instead of the HyperSync technique described here with the latter invariably leading to a graduated exposure acrosse the frame (since a regular full power pulse tails off in intensity rather quickly).
Let me know if you want me to validate your idea with my Cactus gear. I've been using an HSS-capable flash as a trigger for a V6 transmitter and am not sure anymore whether I ever validated the setup suggested by your idea.
