Originally posted by SOldBear Disclaimer: I've never used the YN560 III. What I know is from reading the manual on line.
The 540FGZ has 2 wireless modes:
- SL1 - P-TTL wireless. The 540FGZ is triggered by the built-in flash, or another 540FGZ, or a 360FGZ. This mode requires an elaborate communication between the master (or control) and the slave flash. The sequence:
- The master flash emits the initial strobe. The mirror is still in the down (viewing) position.
- The slave flash emits a reply strobe telling the master that it's ready. This strobe is also used for metering. Mirror goes up.
- Shutters open. The master flash emits a strobe, telling the master to fire, also how much power.
- The slave flash fires the actual strobe. Shutters close and mirror goes down.
- SL2 - Dumb slave. The 540FGZ is triggered by any strobe from anywhere.
The built-in flash has 3 firing modes:
- P-TTL mode: a pre-flash strobe for metering, and a main strobe during exposure.
- P-TTL wireless mode: to control a slave flash as above.
- Manual mode: One strobe during exposure. This mode requires a manual lens being used. I don't know about your camera, but most Pentax DSLRs fire at full power in this mode.
The YN560 III has two slave modes:
- S1: Dumb slave. Triggered by any strobe from anywhere.
- S2: Ignoring the pre-flash strobe as in P-TTL mode, triggered at the second strobe.
You can see that the
only mode in which the 540FGZ and YN560 are compatible is the dumb slave mode. You want the built-in flash to fire only one strobe to trigger both of the slaves. But you need a manual lens to force this mode. If the built-in flash is in P-TTL mode, the pre-flash strobe will trigger the slave flashes before actual exposure.
The best way I can think of is to get a small flash with power ratio settings, set it at the lowest power level and attach it to the camera's hotshoe to trigger the 540FGZ in SL2 and the YN560 in S1 mode.
Important note:
- If you need to put the built-in flash in P-TTL wireless mode for testing, also set the 2 sec delay on the camera. There will be a 2 seconds between step 2 and step 3 in the sequence above. It's easier to observe which flash fires and which does not.
- To make sure the test is valid, do the test in front of a mirror, and make sure all flash units are visible in the photo. Oftentimes, it's difficult or impossible to tell if a flash is firing during actual exposure.
SOldBear, I think that works!
My mistake before was that when I had the 540 FGZ in SL2 and the YN 560 in SL1, the on-board flash was in wireless mode, and for some reason the flashes didn't like that.
Now the on-board flash is just normal (as johnmflores suggested), and with the FGZ in SL2 and the YN560 in SL1 (as per your suggestion), they're both triggered at the same time, and the exposure captures both flashes.
Strobist time!
Thanks both of you!
E
---------- Post added 01-28-15 at 11:06 PM ----------
Okay, just a quick update.
I've been testing this setup again (and going blind in the process). Here's a curious finding.
The setup works the way I want it to, but ONLY if I keep the flashes at 1/4 power or less (which is more than enough for my purposes).
At 1/2 and 1/1, the flashes will fire, but they do not add their light to the exposure.
The fact that both of the flashes seem to stop contributing their flash to the exposure at 1/2 and 1/1 suggests to me that this is some weird Pentax hardware/firmware limitation. I'm not sure, but I'm too tired right now to surf the interwebs for a possible answer, and also my eyes are in agony from all the flashing. I'll do more testing tomorrow.
