06-16-2015, 09:38 AM   #91
Ahab's Avatar
I'm perfectly happy with my AF360FGZII.
06-17-2015, 09:39 AM   #92
I'm also curious as to why they went with AAA vs. AA. The size/weight difference is so small.
12-09-2015, 12:41 PM   #93
Michi Joel's Avatar
Recommend as a replacement for flash integrated K3II ? I guess that will be more powerful and versatile . I'm not using flash but once I've used , so a flash with high performance I do not think they take .
03-21-2017, 04:08 PM   #94
I just got my K-1 which doesn't have a built in flash (no concerns there since my old Pentax camera with built-in worked well but the lens cut off illumination on the bottom of the frame so a high mounted flash would be an improvement). I have a high powered flash that I use when needed, but it's too big and bulky for everyday use, so this flash appears to be ideal to carry in one's pocket and pop on when a fill flash is needed. For those outdoor scenes with more backlighting than front, a small flash makes all the difference in the world for portraits or other close up subject matter. This flash might be a bit under-featured, but appears to be just the thing for an easy take-along when some fill is needed. P-TTL, dust and weather sealed are an added plus.
Opinions?? Any other good candidates for my requirement?
03-21-2017, 07:03 PM   #95
QuoteOriginally posted by Bob 256 Quote
The Metz 26AF-2 is similar in size and specs to the Pentax 201. It's not WR though.
03-21-2017, 07:47 PM   #96
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
I have the AF201FG flash. I use it for my macro work and as long as you don't need it to swivel, nor need of HSS, it is a good flash. I like the fact it's small, because I have a condition that makes my hands shake and a heavy flash on top of the camera and lens weights isn't good for me and the AF201FG is just the right weight. I use it with the power set to 1/4th which is just the right amount of flash for my macro shots, it doesn't blow out whites, nor does it blow out the insect eyes like a more powerful flash does. I used to own the AF360FGZ, but it was too heavy and I couldn't control the light as well either.
03-21-2017, 09:21 PM   #97
AndrewG NY's Avatar
There is also Metz 24 AF-1, less expensive. I think one of these uses 2xAA and the other 2xAAA? I don't think either Metz unit offers the manual 1/1 or 1/4 mode that the AF201FG does.
03-22-2017, 09:01 AM   #98
Will check out the Metz. I thought the AF201FG did swivel vertically. That should be enough for me. Mostly forward facing use anyway. Thank's folks for your input.
03-22-2017, 09:04 AM   #99
It goes from vertically straight back to vertically straight forward but doesn't go horizontal.
03-22-2017, 09:33 AM   #100
acoufap's Avatar
Maybe you'll find some interesting info about AF201FG in my accessory post.
Use it mostly wireless (!) with my K1 using 2 Cactus V6. If your're interested in how I got it working you can read it here. It even works with my old manual lenses. Great also on camera or wired through PTTL cord. Great litte unit IMO.
Last edited by acoufap; 03-22-2017 at 09:39 AM. Reason: Added hint about wireless use.
03-22-2017, 04:36 PM   #101
stub's Avatar
QuoteOriginally posted by boriscleto Quote
If they were WR and P-TTL they might be perfect...
If the new Pentax flash unit was HSS it would solve a lot more issues...
03-23-2017, 03:23 AM   #102
QuoteOriginally posted by stub Quote
AFAIK, no compact flash units on the market support HSS, from any brand (Canon, Nikon, Olympus, Fuji, Sony, Metz included). It's a feature only bigger flashes offer, probably because HSS usually needs power.
03-23-2017, 09:26 AM   #103
Thank's for that info Acoufap. Sound's like a great setup you got using V6 and this little flash. It's also nice to know it supports analog protocols since I still use my Pentax PZ-1p and it would adapt to that as well as the K-1.
Pardon my being a little rusty on my flash acronyms, but what is HSS (I assume it hot shoe something), and would assume from the last two posts that the 201 doesn't support it? Is that something the 340 supports (not to get off topic, but I plan to get a 340 in the future)?
I think I'm getting closer to popping (pun intended) for the 201. Good price and usable features for what I'm after (and it's Pentax).
03-23-2017, 09:43 AM   #104
but what is HSS
It stands for High Speed Sync.
03-27-2017, 02:17 PM   #105
seventysixersfan's Avatar
I've had my eye on the new Metz Mecablitz M400 -- looks really compact and swivels vertically and horizontally, and does HSS I think.
Metz mecablitz M400 Flash for Pentax Cameras MZ M400P B&H Photo
af201 fg, fg, flash, lighting, metz, pentax news, pentax rumors, photo, photo studio, strobist, thread
Excited K-3 newbie TrailRunner Welcomes and Introductions 11 11-01-2014 08:05 PM
Excited sormel Welcomes and Introductions 3 02-10-2014 02:14 AM
A little excited pgamble Welcomes and Introductions 4 02-08-2014 01:19 PM
Excited and a bit apprehensive :) sunniedaze Welcomes and Introductions 6 07-04-2013 01:06 AM
New Fuji X camera to be announced next week. Anyone else excited? leadbelly Non-Pentax Cameras: Canon, Nikon, etc. 181 01-18-2012 02:19 PM
All times are GMT -7. The time now is 09:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
