Originally posted by mattt What "S" mode are you in?
manual K, M, or adapted M42 lenses need the flash set to S2, and the flash will fire wirelessly in Manual as an optical slave.
With an A / F / FA / DA lens you can operate in P-TTL and A modes wirelessly in S1. You will have to ensure the flash is set to the correct channel (1-4). The manual can be a bit cryptic, but Gary Fong has a great YouTube clip with instructions on how to with a K5 and AF 540 FGZ and AF360FGZ.
Any of the cheap Chinese triggers will fire it in M and A modes, but most will not "wake" it up.
Thanks! Your right, that the manual is cryptic! That Gary Fong YouTube was excellent. Unfortunately it confirmed for me that the problem is the off/wireless/on switch on the flash. Its broken...I can go from off to on, but it just slips thru the wireless selector so I can't select anything for wireless. I'm tempted to take it apart but its not worth the trouble...so I guess my options are an external trigger if I want to use this wirelessly.
thanks for the tips,
al
---------- Post added 02-14-15 at 12:59 PM ----------
Originally posted by dborked You could use a Cactus V6. The problem is you would have to get 2, one to mount onto the camera to act as the commander and one to mount the flash to which would be the receiver.
Thanks for the tip here.. looks like a good trigger, but its a tad pricey since I'd need 2. I may just try one of the cheap triggers and see how they work.
Thanks again,
al
