Originally posted by UserAccessDenied ^The onboard flash can adjust -2.0/+1.0... But I don't see a difference. I'm also new to the DSLR world so I may have no idea what I'm talking about
I don't know what I'm talking about either, since I don't have a K-30, but
I've read that those adjustments only work with recent lenses (with which you can shoot P-TTL), and that with old lenses in full manual mode, the flash always fires at full power regardless of that setting. On the K-3, with a full manual lens, you can set the flash anywhere from full to 1/128th power. This is pretty cool for macro but also because it means you can use the onboard to set off an optical slave flash while also making sure that the onboard won't contribute much to the exposure.
