03-07-2015, 07:54 AM   #1
Help with a Canon flash
Hi all, is it safe to shot with a Canon speedlite 540EZ with a pentax K5 camera?, i've read that the trigger voltage is 3.75V, and the flash works in M mode (the camara is in x mode).
Thanks in advance!
03-07-2015, 08:19 AM   #2
jatrax's Avatar
Yes. Trigger voltage is only an issue on older film era flashes. Anything under 12 volt should be fine. Some of the older flashes topped 100 volts.
03-07-2015, 08:41 AM   #3
Yes Jatrax is right. Your flash will be safe to use. I've used flashes with a 20v connection on a K10D with no ill effects.
03-07-2015, 09:35 AM   #4
Thanks! should i cover the extra pins with tape? Only the center one is needed for triggering the flash, and i don't know if those pins would make contact with the camara hot shoe.
03-07-2015, 03:11 PM   #5
willdmo's Avatar
the contacts should be no issue, since the camera and the flash use a different protocoll anyway
canon, flash, lighting, mode, photo studio, strobist
Wireless Flash help with a K30 ronuser Troubleshooting and Beginner Help 13 03-23-2015 05:38 PM
Help needed with a Lexus SB3000AF Flash dave mbe Flashes, Lighting, and Studio 3 01-24-2013 07:26 PM
Pentax K-x with a Canon Speedlite 430 EX II Flash Shub Troubleshooting and Beginner Help 3 03-30-2010 02:54 PM
Help: Using Flash with M Lenses (no A position) Doanh Troubleshooting and Beginner Help 4 01-05-2010 01:11 PM
Need help with deciding on a flash unit jbuttitta Pentax DSLR Discussion 16 06-27-2008 09:07 PM
All times are GMT -7. The time now is 01:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
