Originally posted by Winder
If the construction is as good as you say and they are local with great customer service, then that would be my choice. If you are traveling and have to assemble/dissemble for every shoot, then construction is a big deal. Most of the gear I have damaged has come either in transport or setup/take-down.
yes, the boxes are just impeccable with their construction. It's quite impressive really. The problem with them is that they do not break down as easily as other boxes. Need to release the rods from the speedring every time which I find takes up valuable time (and can be quite frustrating). Just swapping from rod-assembly style rings to rotolux rings for my Elinchrom boxes cut down my setup/teardown time by 15 min at the start and end of every session (for 3 boxes) granted I'm one to fold everything up really nicely too. So saving 30 minutes of valuable studio rental time at $70 an hour so I can shoot more is quite nice.
I'll probably purchase one just to see if there is a way I can adapt the speedring/rod setup from the Strobe-Pro boxes over to the Lightrein, they both use Bowens rings so in theory....
