04-16-2015, 02:27 PM   #1
CarlJF's Avatar
EV and flash on vs wireless
Although I usually use my K-500 in M mode when working with flash (360FGZ), I just played with it in Av mode to see how it goes and if it makes thing easier or not. If I put the flash on the hot shoe, setting EV compensation in the camera for ambient light will also be applied to the flash. Which, I understand, is the way it's supposed to work.
Now, if I rather use the flash as a slave in wireless mode, using the built-in flash as a controller, setting EV compensation in the camera only affects ambient light, as if the EV compensation data isn't passed on the flash in wireless mode. Which for me is great but a bit strange.
So, is it normal that EV compensation doesn't work with the flash the same way depending on the flash being on the camera or in wireless mode ?
04-19-2015, 12:18 PM   #2
I am not really sure, but if you trigger a flash wirelessly using the build-in one, isn't it in fully manual mode? I was under impression that nothing can be transmitted (except the command to trigger)..But I might be wrong, in which case I would like to know the answer..
ambient, camera, compensation, ev, ev and flash, flash, flash on vs, light, lighting, mode, photo studio, strobist
Wireless flash triggers vs. high flash unit voltage Arvid Flashes, Lighting, and Studio 4 02-27-2015 08:18 AM
wireless flash on Kx jeantree Troubleshooting and Beginner Help 3 01-01-2015 04:16 PM
Wireless flash on K-50 Matz Chase Pentax K-30 & K-50 8 09-04-2014 11:04 AM
Switching EV on flash or camera? jboyde Flashes, Lighting, and Studio 4 06-25-2010 03:43 AM
EV Compensation vs apperture and ss adjustment jbrowning Pentax DSLR Discussion 3 04-03-2009 06:12 AM
All times are GMT -7. The time now is 03:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
