Originally posted by geru2000 I'm a little confused, is your flash set to HSS, if so then 1/2000 shouldn't be a problem for the flash.
The shadows on Haley's face aren't caused by the flash performance nor would the flash be able to remove them properly. Using a scrim or even turning her 180 would probably have removed them. The shadows are not unlike dappling found sometimes when under trees.
The flash fired. But the guide number at 1/2000 and the zoom setting used is 15.84 ft. I was at f/2.2, so that gives a range of about 7'. I'm sure I was quite a bit farther away than that, probably 14' or more. Basically, my flash didn't do anything. If I had shot at 1/500 instead, then I would have been in the clear.
Here she is rotated about 90º:
Exposure: 1/5000
Still shadows. (180 would be worse, since the sun would be right into the camera, then. I think that's where it was.) Shot just minutes earlier, I was a little closer to this subject and had a shutter speed of 1/500:
Here's Harley and Black Widow again. Taken from more or less the same spot (same angle, although Widow was farther from the building by a bit) 5 minutes apart:
Exposure: 1/8000 spacespacespacespace spacespace spacespace spaccecee Exposure: 1/400
I'm pretty sure I was closer to Harley as well, since I wanted her hammer to be out of focus. Still, Harley has shadows. I'm still a novice with my flash but I'm pretty sure its the shutter speed. At 1/8000, the guide number at f/2.2 is like 3' and I was definitely farther than that away.
Quote: Anyway some nice and colorful shots.
Thank you!
