I just got my flash and used it outside in bright light for fill in. Here are some results:
Exposure: 1/800 Exposure: 1/400 Exposure: 1/500
Exposure: 1/2000
There's a bunch more of Harley (last girl) photos there if you click the photo and go to my Flickr. Notice the shadows on her face? Yeah, the shutter speed is too high. It's not enough time for the flash to do anything. The 1/400 or 1/500 are much better. Even 1/800 worked out well in that scenario, although it didn't fare as well in others. 1/250 may be ideal, although perhaps a bit slow.
Originally posted by jab2980 Is it common for an external flash to automatically switch from manual mode to P-TTL when shooting in AV mode?
I made this mistake in my first session out. Av mode is not a good choice because the shutter speed will go too high and then you lose all the fill-in. If you set it to HSS, it will stay that way, but PTTL + Av mode is not a supported combination, technically. Or at least, it doesn't work well. The Pentax flash manual says to put it in P, TAv, or M mode.
If you want to do fill-in in bright light, you need to use TAv mode and ND filters. Probably 3 or 4 stops. I need to get a set for my FA31 myself for this purpose. Keep in mind that you can always raise the ISO to 200 to get the exposure up, but you can't lower it below 80 or 100. It's better to see ISO100 at 1/125, which you can turn into ISO200 at 1/250 or ISO250 at 1/320, than to see ISO80 and 1/800. You can't do anything about that if you're maxed out on filters.
