Hi,
i just had a conversation @ Facebook. Someone asked if it is possible to trigger studioflashes beyond 1/160th.
I had the same problem and after buying a lot of useless stuff i found a workaround... wasting 3 days, but worth it.
You don't need the RF603s - just ignore them - you have to use to Cactus V6 - the second V6(V5) triggers the flash I'll change this after work, sorry
You need:
1x HSS compatible Flash (i use the Metz 50AF1)
2x Cactus V6 Triggers
2x RF603NII Triggers (maybe more, depending on how many flashes u use) - only needed for triggering my Yongnuos!
So... what i make is...
I first tried every wireless trigger i found... optical triggers... nothing worked (btw B&H has some optical slaves that could do the job!)
I bought Cactus V6 Triggers... as they bypass the ttl signal... works... even hss with my metz works... but no wireless trigger signal beyond 1/160th.
But it transmits the signal via hotshot. And the cactus v6 has a Delayfunction.I backpacked a yognuo RF603N II on the cactus... straped it on my Metz...
My Metz is on the camera and triggers optical (via flash) the cactus... this one triggers the RF603NII (TX) - goes wireless to the RF603NII and this last one triggers my Jinbei Portys.
The working Delaysetting for the Cactus is ~2ms
Works... looks strange but does the job.
To show some pictures:
Cactus V6 on Slave 2 (Mainflash)
Backpacked RF602N (NIKON!!! - the Canon version causes trouble)
Delay 2ms
Just laid it on the table... it's normaly strapped to the flash which is on cam (Flash pointed back or upwards)
Other RF603NII as receiver triggers Jinbei
Sample:
From upper left to downer right
1/4000th - 1/8000 - 1/200
1/400th - 1/800th - 1/1000
sorry for the mess
