Originally posted by Fat Albert There was no speed ring included with the softbox so I'm trying to get a piece of hardware which will tie in the 4 softbox poles and simultaneously mount on my light stand.
Any ideas?
If you look closely, the rings you are looking at do not include a mounting method for your light stands. The rings are designed to mount to the studio light and the studio light mounts to the light stands.
What I think you can do is remove the flash mount and use that hole to mount the ring to your light stand. It looks like the flash mount hole would allow the 1/4" - 20 hex head screw from my DIY bracket to fit through it (like the extra bracket in the Large Ring). The bottom of the screw then would fit into an umbrella bracket. The umbrella bracket would then attach to your light stand and allow you to tilt the soft box if you desire.
Adorama Universal Swivel Holder - Umbrella Bracket 781404
