Originally posted by panoguy I don't think you will find a more reliable off-camera flash connection than a corded one. Maybe check your cables and connectors? The old AF-540FGZ has a notorious plastic shoe mount foot... it might be getting worn. The new 540II has a metal foot.
FYI: many wireless radio transceivers won't even work well under 3 feet apart, mainly due to interference between their antennas. I know the Cactus V6 has a special "short range mode" which (presumably) lowers the radio output power, but they are manual flash (not P-TTL) only.
Currently, there are no P-TTL radio triggers for Pentax. I say "currently," because I'm working with a developer on a radio trigger that does transmit full P-TTL, but it's not ready for prime time, yet.
In my case, it's definitely the connections and not the flash itself, which fires reliably if seated directly on the camera. I run the extension cord from a hot shoe adapter on the camera directly into the flash unit (as opposed to another adapter). Still, there are too many potential trouble spots to check, which results in some heavy sweating when something goes awry while the bride is walking down the aisle.
Thanks for the short range info on the wireless transmitters. I was not aware of this limitation. More importantly, I wish you much success in your work developing a P-TTL radio trigger and look forward to purchasing a set when they're ready.
---------- Post added 07-02-2015 at 06:43 AM ----------
Originally posted by WPRESTO Reliable flash connection has always been a problem. Old timers like me have long since lost count of how many times we've twisted a plug in a PC socket to try to improve the contact*. With the setup you've described, if you're having trouble with the contacts, replace the cord rather than going wireless. If you go wireless, you will not have PTTL or TTL of any kind, only manual flash control. One thought: the Pentax system has four plug points where connections can go bad: hotshoe to first adapter, first adapter to wire, wire to second adapter, flash to hotshoe on second adapter. Consider a Vello or other TTL wire dedicated to Pentax to eliminate two of the possible connection-failure points. And be sure to twist the locks at wire-to-camera and flash-to-wire so the locking pin engages to keep both inserted contacts fully in position.
*IMHO electronic cable releases suffer the same contact problem. Why on earth manufacturers gave up on mechanical cable releases, a technology proven for over 100 years, defies logic and understanding.
Yes, you've described the set up and the problems perfectly. Too many connections, too many points of potential failure. I've eliminated one connection (flash to hotshoe on second adapter) by connecting the cord directly into the flash unit, which now sits on a dumb hotshoe on the horizontal bar of the bracket. This works fine until the connections begin to fail elsewhere, as they invariably do.
Guess I'll be replacing the hard wire components yet again, until something better comes along. Panoguy's work (see earlier post) sounds very promising.
Thanks for taking the time to respond.
