Originally posted by roy yes!! i use it all the time.. the onboard doesn't but a hotshoe mounted or an off camera flash works great. well at least on my DS it does.
Roy, your experience with DS does
NOT apply to K100D, unfortunately. Once you were using manual lens, you camera and flash would switch to analog TTL mode and NOT P-TTL! All newer Pentax does not have analog TTL support.
So no, Aneopa, P-TTL does NOT work with manual lens. You need at least an "A" lens to work. The reason is that for analog TTL, it does not need to know the aperture set, as it meters the flash exposure in real time during the time when the shutter is open.
However, in P-TTL, the metering is done with a pre-flash and with the aperture wide open. So the camera must know before hand what aperture will be used for the actual exposure so that it can make a projected settings based on the wide open aperture metering.
