A few changes from last time. I adjusted the circle of confusion number on the spreadsheet to narrow the DOF. 70mm f8 4100mm 90mm f8 4500mm 100mm f8 4800mm. All 200 iso, bulb mode. Changed locations a short distance away, and the density was higher. The rpi board would reboot every so often after heavy shooting, I suspect I have another YN560II that is failing. Time to retire them all. Used three YN560III, one YN560II and one AF540FGZII, all set to manual 1/16 power.
There was lots of activity in close, so I think I will not use the 100mm and replace it with a 50mm and set the focus a bit closer in on all three.
This is the best yet.
I did a bulb mode -shutter open-three flash pulses-shutter closed attempt. The background was lit, so it softened the subjects, but this one is interesting. It is the same bat.
A link to the collection.
https://goo.gl/photos/f3uao8gz6TpBEtuM6
