I have read both the Cactus V6 manual and the Pentax AF540 FGZ manual and could not make sense as to how to achieve HSS using both. I was mounting a V6 on my camera's hot shoe and in TX mode. I had another V6 in RX mode with my AF540 FGZ on top of it, and it was in SLAVE MODE. The channels and groups were all set up, I set the external flash (AF540FGZ) on HSS mode, and expected everything to work fine. NOPE. And now reading the comments here, I find that I only needed the AF540FGZ as a means of achieving HSS with an RF60 in HSS Sympathy mode. So basically I need:
(2) V-6 transceivers
(1) RF 60
(1) AF540 FGZ in HSS mode.
I have read somewhere in this forum where someone else had the same problem with getting everything to communicate, so he had to put a V6 on top of his AF540FGZ. Yikes!
The reason I invested in Cactus equipment was because it was compatible with Pentax as well as other brands, and I could also use old film flashes with it.
And by the way, I HAVE used the technique that 'Class A' described for using a Cactus RF60 / V6 with non dedicated equipment. I used that method several months ago with a cheapy Rokinon flash and a potato masher Sunpak. It worked, but it was just a little wonky and unreliable. I had to be very careful about waiting for the flash to cycle up and see if both V6s would flash green to see if they were communicating. The technique was about 60% effective, but at the time, it's all I had. This time, I have the AF540FGZ and was hoping for better results, or at least results. I did copy and pasted some notes from this forum about other methods people have used to get HSS working with Cactus equipment. I don't want to give up on Cactus quite yet. It's just I feel limited by what I can do with Pentax right now.
---------- Post added 05-18-16 at 11:11 PM ----------
Originally posted by clackers I think any brand is going to be tough for you if you don't read manuals, Kay! ☺
I did read the manuals. Still no answers.
