.Thank you, Class A, for having patience with me and helping me out with this confusing situation.
"Without Pentax's annoying disabling of a trigger signal beyond the sync-speed, you could at least go up to about 1/2000s with what you've got already. Only even faster speeds truly require a pre-sync signal."
Wait, wait, wait...lol...I could get up to 1/2000 of a second with what I already have? Seriously? That would be nice! I am just aiming for something over 1/180th right now. It would be a miracle if I could get past that. Okay, despite all the online resources I've been reading and taking notes, I still wouldn't know how to get a sync speed past 1/180th sec. Do I just turn off the TTL on the V6? ARRGGHHHH!!! This is confusing and frustrating. Please bear with me. This is all new and foreign to me. I've read articles regarding having multiple V6 units and / or multiple RF60s and / or an HSS enabled flash, but I could not find anything regarding using a single RF60 and a single V6 together to get the HSS going. I need to know specific settings for each. Damn Pentax for being such a pain. :-(
---------- Post added 11-13-15 at 10:24 PM ----------
Maybe I should just invest in a few more V6 units. But that will have to wait until December or January.
---------- Post added 11-13-15 at 10:30 PM ----------
Originally posted by Class A True, you'd need two more V6 and a shutter release cable, or alternatively, one HSS-capable flash to get pre-sync timing from a Pentax camera.
You could, if you got a V6 receiver for the flash.
Since the Rokinon flash supports TTL (and supports manual levels, right?), chances are that you could even remote control the power of the flash (not just trigger it). You can use your one V6 and try to create a flash profile for your Rokinon flash. If that works, you'd only need another V6 so that you have a trigger / receiver pair.
My Rokinon supports TTL, but the only flash profiles on the V6 are for all the big names, and then there's MANUAL. Nothing about Rokinon or any other third-party flashes.
---------- Post added 11-13-15 at 11:05 PM ----------
I just popped the Rokinon flash on top of the V6 and tried to get the V6 to recognize it. It doesn't. I can put the Rokinon flash in TTL mode and in Manual mode and go through the menu on the V6, but it isn't recognized. Back to Square 1.
