Originally posted by stevebrot For most models, the time for preflash and calculation delay is about 0.02s.
Where do you get that figure from?
According to
Imaging Resource measurements the overall time added by using flash (on the K-5) is 0.102s (see "Shutter Response (Lag Time)" and take the difference between the respective normal and "flash enabled" measurements). EDIT:
Measurements by lister6520 even report 0.13-0.16s delay on the K-30 (and 0.31s-0.33s for the K-3) when using external flash.
I'd say for shooting action (moving kids), this is a considerable delay. The delay added by the K-3 (another 0.19s) leads to an overall entirely unacceptable delay.
One of the significant advantages of DSLRs over P&S cameras has been the considerable difference in shutter lag. If the OP does not need / want to capture decisive moments then I understand, but in general a noticeable shutter lag (whether caused by a pre-flash + metering or something else) is detrimental to photographing action.
Originally posted by RGlasel The time delay involved in retaking pictures is far longer than anything the P-TTL system produces.
Sure, but with Auto-Flash (as available on the FGZ models), you don't get any delay, and with manual flash, you have an initial delay once (to figure out the right setting) but then every capture is done without further delays.
Originally posted by mcgregni I'm not aware of any specific test comparisons between the older type 'red cross bars' AF assist beam and the new LED spotbeam technology.
I don't know of any either, but it is clear that the red cross type approach has advantages over a uniform AF light since it will create additional contrast for the AF system to latch on. With a red cross type approach, you can even focus on a white wall (or white shirt, for that matter), whereas a uniform AF light will provide no such support. I would expect the older approach to outperform the newer approach in terms of focusing speed, unless the LED is rather bright.
@pathdoc: Do you know how images using direct on-camera flash (i.e., without bouncing or diffusion) look like? If you do and don't mind the look, I'm of course fine with that. I'm of the opinion they are typically not worth taking. I'd get a light stand and a softbox (which can also protect a regular flash against some light rain) and use off-camera flash.
Originally posted by derekkite My theory, hmmm, hmmm, is that the AF tracking is ineffective for the same reason there is a delay in the Pttl flash; the metering sensor communication bus is slow.
AF is done through an entirely different system (using a sub-mirror behind the main mirror and a module at the bottom of the camera, whereas the metering module is attached to the prism).
