P-TTL introduces a delay. If it is too long of a delay for your use is hard to say.
A sure fire way to avoid a delay is to go with an older flash that supports "Auto Flash". It doesn't have to be older than the previous generations like the AF360FGZ or
AF500 FTZ, which both have AF assist. If you could forgo AF assist (use manual focus) you could go further back in time to flashes which can be had for a song. The
AF280T would be an example of an older powerful flash which is still reasonably compact. If you go for a cheap second hand flash, perhaps Santa would bring you something else for night use like a fast 50mm or 77mm F1.8 prime?
In Auto Flash mode there is no delay. The exposure is cut off by the flash when it detects that sufficient light has been reflected from the scene. Exposure accuracy is surprisingly good.
