Originally posted by mcgregni It's not my words about that, it's Chris Giles.
That's why I wrote "
As to Chris Giles' statements:". I'll tidy up the post to avoid confusion.
Originally posted by mcgregni It's good to see someone working at that level who is making such positive comparisons with Canon equipment.
Except that his comments do not make much sense ("...
true wireless..." vs "...
infrared..."?).
Apparently you don't know what this (and other statements) is supposed to mean either.
Originally posted by mcgregni I don't find any inconsistencies with bounce on the K7
Well, good for you but there are many, many threads about users complaining about P-TTL exposures on the K-5. Given that Ricoh admitted to a hardware limitation shared with the K-7 I can only assume that the same problems existed on the K-7 already. Maybe there are differences, as I believe the real P-TTL complaints came with the K-5; perhaps I missed the K-7 ones, I don't know.
Originally posted by mcgregni It is a normal part of the workflow to use Flash Compensation and take positive control to tell the system what you need.
If that's the case then that severely diminishes the utility of automatic exposures, AFAIC. If one has to take a couple of attempts to find the right compensation value, one does not appear to be quicker than someone finding their correct manual level (guessing the right ballpark is not hard with a bit of experience).
Originally posted by mcgregni It's mainly about the communication aspects between camera and flash (and that mostly benefits on-camera work, yes, but there is wireless communicated compensations there as well if needed).
But any camera/flash communication relies on P-TTL. Perhaps you meant "automatic exposure" instead of "P-TTL"? I don't understand to what end "
communication aspects" could be useful; perhaps you mean the indication of flash reach on the flash display which only works for direct flash? I wouldn't count the latter as a noteworthy feature because of the bad quality direct flash has.
Originally posted by mcgregni I wrote 6 new pages for the guide exactly about this sort of discussion, and that was mainly in response to your feedback and questioning ClassA, so I'm not going to try and detail it all here again. It's on pages 14-19 for those interested (in the new edition)
OK, thanks for the pointer.
Originally posted by mcgregni So probably you and I should not lock horns on it, and instead just accept that an automatic dedicated system will suit some, and a radio manual system will suit others.
I don't see anyone "locking horns".
I regard it as entirely normal on a discussion form to ask questions about something someone else wrote. I didn't understand what you were referencing when alluding to things on a dedicated system beyond P-TTL mode, so I asked. One of my speedlights supports P-TTL and if I may learn anything about how I may exploit its functionality better, why shouldn't I ask?
EDIT: I agree that different approaches suit different people / preferences. Agreeing to disagree on some aspects is fine.
That shouldn't stop us, however, to probe whether some perceived benefits are actually helping and whether the price to pay to obtain them may be too high (no pun intended).
