Originally posted by mcgregni Of course there will be times when I want everything manual, but I'm not yet sure if the Pentax flashes could be controlled from the V6 without other V6 receivers attached to them ??
For every (non-RF60) flash you want to trigger via radio or even remote power control, you need one V6 receiver.
An on-camera V6 in transmitter mode uses radio signals for communication. While RF60 flashes have a V6 built-in, any other flash model requires a V6 receiver (i.e., a V6 unit in receiver mode).
For Pentax flashes to be controlled from an on-camera V6 without using extra V6 receivers, the communication would have to be optical, defeating all the advantages of radio communication. Of course, if you use a P-TTL flash on an on-camera V6 then the latter can control Pentax flashes "wirelessly" (optically) without the need for additional V6 receivers.
Originally posted by mcgregni In which case I'm not sure where the optical trigger would be coming from ..... ?
The V6 does not use optical communication, so as I said if you want to use Pentax flashes off-camera without using V6 receivers with them, your only option is to put a P-TTL capable flash on to of the on-camera V6.
Originally posted by mcgregni I can just temporarily switch off the slave units while working with the single on-camera in the more dynamic way.
Yes, turning an off-camera flash on or off, i.e., toggling its on/off status, is achieved by pressing the respective group button. The V6 has four dedicated buttons, so you have immediate control over up to four individual units, but of course you can combine, say two, units in one group, so that you can control both units with one press.
Originally posted by mcgregni I assume the V6 pass through function allows full functioning on the Pentax flash attached on top , including HSS?
Yes.
Originally posted by mcgregni Also, would the Pass through allow wireless HSS (optically I assume) with both the 2nd Pentax slave AND the RF60 (in HSS sympathy mode)...? (I mean both firing together in sync ....im aware there has to be a delay programmed into the RF60).
The "pass-through" does what it says: It passes-through all communication as is, so all P-TTL functionality of an on-camera (on V6) flash is retained.
Putting a P-TTL HSS capable flash on an on-camera V6 with TTL pass-through enabled, allows HSS flash photography and thus taking the shutter speed beyond 1/180s. Unfortunately, however, the Pentax engineers decided to still suppress the standard hot-shoe triggering signal in that case. This means that the V6 will not be triggered (it just passes the data through to the flash on top of it, but does not receiver a proper triggering signal from the camera itself). This is a pain and Nikon shows that it need not be that way.
As a result, in order to involve an off-camera RF60 (or any other flash combined with a V6 receiver) in an HSS setup, you'll have to pick one of the below:
- optically trigger the RF60 (forgoing the radio communication the RF60 is capable of).
- optically trigger the V6, which in turn will trigger any number of off-camera flashes via radio. Optically triggering an on-camera V6 is not hard to do, but can lead to a clumsier than necessary setup, or requires you to hold the V6 against the on-camera flash each time you take a shot.
- use my (not yet patented ) idea of triggering a camera and flashes at the "same" time (this requires a camera release cable, which however is dead cheap).
Only with approach 3. you'll definitely have to use manual delays. With the other two options, you should be able to not use any delays unless you want to take your shutter speed above 1/2000s and need all of the the frame illuminated.
