Originally posted by awaldram And how would you divide it to each flash what ratio it was firing without some means of addressing it uniquely.?
I'd do it by working out the overall exposure needed for the scene and then calculating the required individual levels based on the ratios specified.
The way I understood your test, it doesn't prove that individual metering is performed.
I'd test it by setting two flashes to 1/2 contribution each and letting them fire on a wall from the same distance, preferably with snoots to see their individual contributions. This should produce two equally bright spots.
Next, I'd move one flash further away and take a second shot of the wall. If the spots remain equally bright then individual metering occurred. If the spot produced by the flash further away becomes darker then only overall metering takes place.
EDIT: I would have tried that test myself, but I just re-learned that my second dedicated flash only supports TTL, but not P-TTL. In other words, I don't have two P-TTL flashes to perform the test with.
