Originally posted by Tonytee Okay I decided to return to the drawing board. I set my Nikon SB-24 ISO 200, aperture at f/8 and zoom at 85 mm.
My Pentax K100D super Camera at ISO 200, shutter dial set at Autopict. From there I went into my light less living room, aimed the camera at a very dark spot, slowly pressed the shutter release. The flash fired as expected, however, the plot thickens here, the shutter speed was set at 4 and aperture at f/4 according to the info in the viewfinder, so what happened was, the shutter remained open for approximately 5 seconds after the flash did its job. Needless to say the photo was overexposed. I forgot to mention that the flash was set at the TTL position. So, again trying to manipulate the flash and camera to work the way I wanted them to, I reset everything back to manual and the pics came out just fine. Here is another thought. I believe that a serious photographer should stick to the dedicated devices that are manufactured for the express use of same brand equipment. Sure, it will cost more, but here is one consolation: Let's say you purchase new a Nikon SB-whatever flash unit and it malfunctions. You return it to Nikon and they cannot claim that the reason for the malfunction was because you used it on a camera it was not made to be used with. They will find any excuse to get out of warranty work. I know because my wife had that very same problem with Nikon. Speaking for myself, the SB-24 will stay with my Nikon Digital Camera. As for the Pentax, it has a very good onboard flash unit that I try not to use frequently because it has an insatiable appetite for batteries. Well, I hope this helps.
Rgds,
Tonytee
The SB-24 should be fine as a manual flash, Tony.
I use a Pentax flash on a Sony from time to time.
P-TTL is manufacturer specific, that was your error.
