Originally posted by CarlJF Have you tried cleaning the flash hotshoe pins ? A pencil eraser something makes wonders for this...
Thanks for this tip. I tried it to no effect, but still a nice tip for the tuture.
---------- Post added 11-29-15 at 04:15 PM ----------
Originally posted by wombat2go On the one here, there is a slight and variable delay after each button press before the zoom setting is displayed.
That delay is longest when the motor has to drive it for the longest time from 85mm back to 24mm.
So I surmise that the display is taken from the actual position after the movement.
In that case maybe your motor drive is the problem. The motor is quite audible.
Can you hear it running to each position?
Thanks for this suggestion. Since the button that changes the focal length setting does not operate to change settings, it is not possible to sense the motor drive sound level or judge anything else about the operation of the motor drive. However, the very fact that one cannot hear the sound of the drive leads me to agree with your suggestion that the motor drive is the problem. Motor drive failure would seem to be consistent with the symptom of invariant focal length settings.
Further to the previous, I might mention that the flash unit, when set up on either of two of my filmless cameras (K-3 and K-5II), seems to be providing perfect or near-perfect exposures in both P-TTL and A modes, suggesting that the unit's circuitry is in some respect operating properly, perhaps just making the necessary changes in light output level to accommodate the invariant focal length settings of 20mm and 24mm respectively. Perfect exposures can also be obtained in M mode by chimping output level (1, 1/2/ 1/4, 1/8, 1/16, etc.), aperture, and ISO settings. These results would seem to be logically consistent with the diagnosis of a failed motor drive.
Thanks for your suggestions, which seem to have led to a correct diagnosis.
