Originally posted by jeffw The board room is at an Airport with one wall all glass. I am worried about shadows and all of the lighting is LED inside of the room. I can get some test shots to check out results .[COLOR="Silver"]
I would make sure to include a grey card or other neutral object in your test shots so you can figure out the colour temperature of the ambient. If you end up utilizing both flash and ambient, you'll want to gel the flash to a compatible colour.
Originally posted by clackers Indeed, Brian, second's a mistake on my part, here's what it should have been (improvised event shooting, HSS because it was the sunniest of summer days), followed by a reminder of what I enjoy more (controlled circumstances, indoors, off camera softbox, etc).
I may be mistaken, but the contribution of the flash looks pretty darn weak and the photo looks to have had an edit or two on it:P. The fong-spheres are just too small to make much of a difference to the soft/hard characteristic of the light at comfortable people shooting ranges outdoors. Yes it will be a bigger source, but frankly not big enough that the edges of the shadows will be noticeably softer unless you're all up in someones grill. And yes, I've used one that even for the magical price of 'free' I didn't keep. I'm not a big event/people photographer type though, so maybe I could have come to appreciate it in more cramped settings.
As I see it, the parts that work in your examples (and the Fong-adverts when they did things right in the tupperwares favour) are (I'm carrying on here because I think this may be a useful discussion for the OP
1-
Ambient and flash working well together. If you overpower the ambient, all the shadows from the flash will be very deep. If this is combined with hard-edged and unnaturally positioned shadows of a direct on-camera flash, the shadows can get obnoxious fast. Either flash or ambient can work as key with the other lifting up the shadows, who does what depends on the situation but they should be friends.
2-
Well controlled white balance. The flash and the ambient aren't at odds colour wise, and care was taken that the WB was properly set for the key light.
Handling these two will go a long way to avoid the 'deer in headlights flashed look', especially when you have no or little control over:
3-
The direction of the flash. Light originating from the viewers position is really not natural, unless you're a firefly. Which, if you're reading this, you're not. The first link for the "Black Foamy Thing" shows how bouncing to the side can yield excellent and natural looking results. Off camera lights can of course be grand (as your second example shows
), but not always feasible at event type things (as I'm sure most know
4-
The size of the light source. Big source means softer edged shadows, which are generally less objectionable, even if they are very deep. A smooth transition into a deep pool of black doesn't jump out nearly as much as a sharp transition to black. There's little you can do here with an on camera flash if you have nothing to bounce off of and you aren't willing to add a huge softbox to your flash, or aren't willing to shoot from a few inches away (an on camera softbox ~6" across can work wonders for macro
As I see it, "messing up" all of the above is the hallmark of a poorly used, direct on-camera flash.
