Originally posted by mcgregni My interpretation of what is reported on the 'p-ttl matt.dm' website is that both Metz58 models have a firmware bug that has never been fixed ...
This website has not been updated in years.
For the 58 AF-2 the information on the "
latest" firmware is: "
3.0 (Jul. 27, 2012)".
In reality, the
latest firmware for Pentax is 4.1 (26.06.2013).
I'm unaware of any bugs in the 4.1 firmware.
When one activates the master/controller option, the ability to use HSS disappears. That's all and is just a lack of functionality, not a bug.
N.B., in my experiments the Metz apparently was not in "controller" mode, because otherwise I would not have been able to shoot at 1/1000s and faster.
Originally posted by mcgregni This apparently prevents them from operating as on-camera p-ttl wireless triggers (ie exactly what you have been trying to do) .
It works fine as an on-camera P-TTL wireless trigger, it just cannot do HSS at the same time. Not a loss for me (and many others, I suspect) because not too many will fire another P-TTL HSS flash optically, and if they intend the latter, they can just reverse the flash roles (unless they have two 58 AF-2).
Originally posted by mcgregni Surely it means they cannot act as both master AND controllers?
You can select "master" or "controller" (but not retain HSS).
Originally posted by mcgregni Assuming this is still correct, then is it possible the bug means that even though set to ' controller' mode in fact the required extra pre flash for wireless is not being sent from the Metz?
Again, I don't think there is a bug in 4.1 and in any event I did not use "controller" mode as I needed to work with HSS enabled.
Originally posted by mcgregni I'm not familiar with the Metz but presumably, like the Pentax models, there's a clearly indicated difference between 'normal' p-ttl HSS and wireless HSS mode?
The 58 AF-2 supports the difference between "normal" and "master/controller". "Wireless HSS mode" is not available on the 58 AF-2.
Originally posted by mcgregni Wireless would have the 'master' vs 'control' sub-setting and should be indicated also.
Yes, the sub-setting exists (but HSS is not available at the same time).
Originally posted by mcgregni It does seem to me apparent now that a listing of RF60 delay settings for different camera models needs to include specific lists for the different triggering techniques ...ie, normal HSS, and wireless HSS (control and master modes)
In general, I agree.
Normally, I don't think there are too many different cases, though. The 58 AF-2 works as expected (no delay necessary for main flash triggering) and the delay you need may be caused by something specific to the 540 FGZ II. Perhaps it is necessary for other flash models as well, or for all P-TTL flashes used as an HSS master (as opposed to standard HSS)?
Originally posted by mcgregni And could these even have differing timings beaten pre-flashes from different p-ttl flashes .... ?
It seems unlikely to me that different flash models would have an impact on the timing, as the latter appears to be determined by the camera.
Different camera models, on the other hand, definitely cause different P-TTL timings.
Originally posted by mcgregni Finally here, as I said in the previous post, I had the AF-540fgzII (in wireless controller mode) pointed directly into the image scene, and on the test shots where the delay was wrong and the RF60 did not fire, I saw absolutely no lighting from the controller at all.
You probably would see some contribution if you changed exposure settings.
I can clearly see a contribution from the on-board flash in controller mode. It is faint, but it is there.
If you take a picture of your camera (and flash) in the mirror, you should be able to see the control flash (unless the FGZ II models do something different to any other flash model before). Might be interesting for you to check whether you can see an on-board controller flash vs an on-camera 540 FGZ (II) controller flash.
