Originally posted by Digitalis The problem with using battery packs with pentax flash units is that you still need batteries in the flash unit itself for it to work in the first place.
This applies ONLY to the use of a high-voltage external power pack (e.g. Quantum Turbo). The purposes of the high-voltage power pack are (1) shorten the cycle time and (2) minimize or eliminate the need to change batteries. Some flash units, especially ones with LCD display (e.g. Pentax AF540FGZ first version), still need low voltage from the internal batteries for the display/camera interface. Others (e.g. Sunpak 444D or Metz 45CT-4) don't. Note that to use high-voltage power pack, the flash has to have an input port for such. I don't think the Pentax 360FGZ does.
The OP is adapting the flash to use with a low-voltage external power pack. In this case, the flash doesn't know and doesn't care where the voltage supply comes from.
Side note: Pentax/Ricoh eliminated the high-voltage input port in the current version of the 540 flash. What a shame.
---------- Post added 01-11-2016 at 12:23 PM ----------
Originally posted by p38arover
Originally posted by Digitalis:
>> I recall reading in the flash manual for the AF540FGZ that you still need batteries in the compartment to use it with external battery packs. I assumed the AF360FGZ would be the same.
The user manual for my Sunpak DX8R ring flash does say that, too, but I assume that's when one has an external pack that isn't wired to completely replace the internal pack.
This is true. But the low-voltage from internal batteries of the Sunpak is used to power ONLY the interface with the camera (as in TTL mode). If you use the DX8R in manual or auto thryristor mode, the internal batteries are not needed.
Lifted from the manual: "Even when your auto DX 8R is used with external power sources, always store batteries inside for dedicated function. Your auto DX 8R is not interfaced to the camera without internal batteries."
