Hi guys,
I would like to share the experience I had when buying a 3 flash off camera set from ebay.
There is absolutely nothing wrong the flash units themselves, in fact the Yongnuo YN 560 IV is possibly one of the best manual flashes I have used in a while, and the 560 TX is fantastic (just make certain to get the Nikon model TX for Pentax cameras)
What I am referring to if the "NiMH" batteries that come with some of the units, these are dodgy to say the least, and dangerous at worst which could cause serious injury / property damage.
The batteries were indicated as 2600 mAh LR6 batteries, they were branded TangsFire, and each flash unit came with a set of 8, it was an extra $8 on top of the price without batts, so thought these would be of reasonable quality (I did not expect eneloop pro).
OK, the flashes arrive together with the 560 TX, great setup, works fine, charged 8 of the batteries, NiMH mode indicates "wrong type" on four of the batteries.
OK time to pull out the aging brick that is my Uniross NiCad charger, I was thinking, okay, NiCad batteries are good enough for the time being, it's just a stopgap until i can get another 24 eneloops... two of the four batteries got really hot REALLY quickly, started producing an acrid smell, started producing smoke and the charger shut down indicating a thermal runaway.
Those that were NiMH batteries (of the 24 that arrived, 16 were NiMH) held nothing like 2600 mAh, more like 600 mAh, pretty much junk.
I contacted the seller, advised the issue and they immediately refunded me for the batteries, explained that they buy the batteries in buk and they cannot test every battery, they apologised for the inconvenience.
Got a pleasant surprise when 1 week later another 560 IV flash unit arrived together with a set of rogue gels express air freight together with a letter of apology.
Great service from the store, cannot fault the sevice, nor the hardware, the flash units and transmitter are fantastic just really disappointed in the batteries.
Moral of the story is to buy the batteries separate.
Cheers
Leon
Reason: bad spelling.
