Originally posted by bertwert Controlling the voltage to them would change the brightness... no?
It won't be connected to the camera in any way... so I could use 1/6000 if I wanted
That was the question I wanted answered most...
Thanks for your opinions.
And in case I wasn't clear this is a light that is on 'all the time' instead of a flash.
Generally LEDs are not dimmable. They are very digital, on or off. Some may have built-in circuitry to allow dimming, but if not, you will need to create your own circut.
As far as the high shutter speed, I was assuming a "constant-on" light.
Most (all??) LEDs need to flash to create a sense of differing brightness. This may lead to unpredictable result with regard to brightness or even total darkness if the shutter speed is faster than the dimming circuit.
I know LED panels are becoming more popular for photography. I assume more for portrait; i.e. in the range of 1/125 - 1/250 shutter speeds.
But maybe there is newer tech out there that makes LED feasible for higher shutter speeds. ????
Regardless, you will want to have details on your specific LEDs. Hopefully they will work.
Can't hurt much to try it. At worst they simple go out at lower voltages.
---------- Post added 01-22-16 at 07:07 PM ----------
... which by the way the next video on the LED panel mentions voltage modulation instead of pulse width modulation (PWW) which eliminates the flickering.
I learned something new. I will definitely look into building a few of these! :-)
