I thought that was for the battery compartment cover. If that activates a locking mechanism, how does it work? Clearly it's not a threaded clamp as used to be common. Nor does it look to be cam actuated, but I can't really tell.
Anyway, the idea of a shim is just to tighten up the tolerance, take up the slack. You might try a horseshoe shape piece of thin plastic between whatever lock mechanism there is and whatever it mounts against, as proof of concept before attempting any more permanent solutions.
Originally posted by awaldram I'd guess the switch with 'LOCK' written above could conceivably be the lock switch !
---------- Post added Jan 26th, 2016 at 08:06 AM ----------
Also, if that slide is for the locking mechanism, it does not look fully engaged.
