I will be shooting an outdoor wedding in April for a friend who may not be able to fit a professional photographer into the budget. I'm reasonably well set for lenses, and will use my K3 with my son's K30 as backup (my K5 is overseas with my other son for 6 months). However, lighting is my main concern.
I have a Metz 52 AF-1, but being outdoors, I won't have walls or ceilings to bounce off. What sort of diffuser, reflector, or other attachment would be best to soften the light? I can place the flash on a tripod if necessary and use the on-camera flash to trigger it for some formal shots. But the Metz will be on-camera for the less formal opportunities I expect. I don't mind using the excuse to buy a little bit of kit for flash portraiture (within reason).
Would you use P-TTL or manual?
