02-02-2016, 08:56 PM   #16
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by trishytee Quote
Thanks, clackers, for actually addressing me, and my problem. I seem to have mislaid the cable, but shall get another. I am thinking that if the Pentax dedicated works on the camera at any shutter speed, then the hot shoe cable is just an extension of the flash, so that's why it would have worked at the wedding.
Cheers, Trish
That's right.
I use one that's not particularly long with a metal bracket, but I have also held my hand containing the flash out to the side and up, uncoiling it.
02-02-2016, 11:12 PM   #17
QuoteOriginally posted by Oldbayrunner Quote
Ok, that's cool it only needs one flash as a slave. I venture to think that flash has to be Pttl Hss compatible in slave mode such as your 540. I know my af540fgz's are but my sigma 610 super isn't. It will only perform pttl Hss as a controller not as a slave.
I have no Sigma 610 super, but since that flash can do HSS on camera as far as I know it would probably work as well on the acons, simply because their concept does not require something to be "slave" or "master" in any setting, since that is a concept only applicable for multi flash setups.
If the flash standalone works on the camera with HSS then it should work on the acons as well, just as with any PTTL cable.
02-03-2016, 02:33 PM   #18
mcgregni's Avatar
The Pentax accessory flashes, (AF-540FGZ I or II), plus probably some of the higher specced third party options, allow the on-camera trigger flash to function as either a 'master' (adds it's light to the scene) or ' controller' (does not ) . So you have the flexibility as needed to either restrict the effects to your slave unit, or include some effect from the camera position ....
In my opinion, there are plenty of good ways to use an on-camera light in conjunction with a slave, most obviously as front fill for HSS portraits, so in fact my on-camera trigger flash is usually set to 'master' for my HSS work. Makes it seem less like a waste a money. ...... !
camera, flash, light, photography, sunset, wedding
Using off camera flash ChuckB28 Troubleshooting and Beginner Help 7 08-19-2013 05:53 AM
Need to disable in-built flash when using off camera flash Molly Flashes, Lighting, and Studio 18 03-27-2013 04:12 AM
silly question - using flash off camera eclipsed450 Troubleshooting and Beginner Help 13 10-02-2010 03:16 PM
First photoshoot using off camera flash. turbosaturn Post Your Photos! 3 12-31-2008 08:04 AM
First portraits using off-camera flash barendvl Post Your Photos! 2 07-31-2007 02:53 PM
All times are GMT -7. The time now is 04:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
