Originally posted by and But the triggering flash happens before the exposure! You press the shutter release but the shutter has not opened yet. This happens in microseaconds, you wont be able to tell that it happens before.
You can experiment with this, take an object, use settings that will make the scene go dark if it hadnt been lit by flash, then turn the external flash off. does the picture become dark? position the remote flash directly to the side of the subject, does it become side lit.
Well, this is what I've been trying to do, but with no luck.
I'm trying to shoot a picture of something in a mirror (so that I can see both flashes) and so both flashes can be seen firing in every shot.
Naturally this isn't anything like the actual conditions that I'll be shooting in when I use the flash for real, but I'd like to get this problem solved before I start using it with models.
Originally posted by amoringello Alternatively, set your flashes to Slave Mode 2 to be dumb slaves, go in full manual mode and use a radio trigger on one or all of your flashes. (You could also use a hot shoe adapter and a plain PC cable. Adapter needed for K10D, I think K20 has a PC cable connection again??)
This may be what I have to do in the end, but I'd really like to get the advertised wireless functionality of this flash working. A big reason why I picked the more expensive Pentax-branded flash over some cheapo Vivitar was that it supposedly did painless wireless without the need for cords and hot shoe adapters.
Also then I'd need 2 PC adapters, one for the K10D and one for the AF-360 since it doesn't have a PC connection.
SETTINGS I USE:
1) Turn on the camera and set to Av mode.
2) Use FN button to set the flash mode to Wireless Mode, go to Custom Settings in the Menu mode and set the Flash in Wireless Mode to OFF.
3) Turn flash on in Wireless mode, with the S (Sync) setting. P-TTL, with Zoom set to AUTO, leading shutter curtain sync.
Not really sure what else to do.
The manual is outdated (2003) and confusing, and was clearly written for the *ist series cameras, with no specific information mentioning the K10, K100, K20, or K200.
