02-10-2016, 07:33 PM   #16
Dewman's Avatar
My remote flash transmitter and receivers came today and I must say, I was quite pleased with the whole set-up. Very well packaged, well-made, attractively designed and it works as advertised! And, all for less than $25.00! I consider that a good deal!
I took it outside and gave it a test ride using a couple of Pentax AF200S flash units and it works like a charm. Now, I have a couple of questions, if I may.
What would you suggest as an "ASA" setting on the flash unit?
I have a couple of Vivitar ZoomThryristor 3500 flash units. Would they be safe to use? Am I in danger of "frying" something using them? Other than having the swivel/tilt head, do they offer anything different than the Pentax units? Perhaps more light?
02-11-2016, 09:31 AM   #17
QuoteOriginally posted by Oldbayrunner Quote
Both Acon and Aokatec are Pttl/hss pttl compatible wireless radios.
Do you have experience with them? I'm interested! Thanks
02-11-2016, 09:34 AM   #18
QuoteOriginally posted by Dewman Quote
Should be safe, though to be sure you should check the voltage with a digital multimeter.
Photo Strobe Trigger Voltages
02-11-2016, 09:50 AM   #19
I've used a Vivitar 3700 (1980's flash) with my remotes with no issue. I now use a couple of Sunpak 333 flashes because they have adjustable manual settings (1/16, 1/8, etc. power).
Tim
ambient, camera, control, controls, fire, flash, issue, item, light, lighting, mode, pc, photo studio, radio, remote flash, set-up, strobist, triggers
Easiest way to mount M42 lenses on K-3? uday029 Pentax DSLR Discussion 27 02-27-2015 06:27 AM
Easiest way to access the shutter mechanism in ME Super? millsware Pentax Film SLR Discussion 5 03-12-2014 12:11 AM
Wife Started Menopause--Easiest Way to Kill Myself? Ira General Talk 47 12-14-2010 06:54 PM
best way to use built in flash? furby Pentax DSLR Discussion 8 10-01-2008 01:32 PM
What's the easiest way to process RAW shots for a total RAW noob? Grimlock Digital Processing, Software, and Printing 6 09-03-2008 02:22 PM
All times are GMT -7. The time now is 11:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
