02-15-2016, 04:01 PM   #16
mattt's Avatar
I have shot this way so often.. do you think I can recall how I do it. I will give it a try this evening to see if I can offer any suggestions.
For kicks, have you tried it with a dumb lens (K mount, instead of KAF3 )?
02-15-2016, 05:31 PM   #17
Oldbayrunner's Avatar
QuoteOriginally posted by chiefsilverback Quote
Yet more confusion! The pre-flash thing is definitely confusing because as you can see from my images at 1/8 and 1/16 power the flashes do work, but any higher and they have no impact on the exposure!?!?!
If your using wireless forget about SL2. I'll break out my K5lls tomorrow and my Af 540's and try to figure out what may be the problem. Looking at te photos it doesn't appear to me the flash fired in the first ones. You sure the Receiver s facing towards the onboard?
02-15-2016, 06:10 PM   #18
QuoteOriginally posted by Oldbayrunner Quote
If your using wireless forget about SL2. I'll break out my K5lls tomorrow and my Af 540's a try t figure out what may be the problem. Looking at te photos it doesn't appear to me the flash fired in the first ones. You sure the Receiver s facing towards the onboard?
Flashes are definitely firing, I've been blinded many times checking!
02-15-2016, 06:18 PM   #19
12345's Avatar
FWIW, I use my K-5IIs to trigger my Yongnuo speedlights via slave all the time. (See my sig for YN flash model #s)
02-15-2016, 06:22 PM   #20
mattt's Avatar
Flash settings:
M Mode
Zoom set to 16 MM
Based on the exposures below, 5.6 was at 1/64, incrementally increased in power to 22 where it was set at 1/8 power
SL1
And obviously the flash is set as slave and in Wireless Mode
My K5 IIs is set to wireless flash in commander mode.
One image below ther is use with K 55mm 2 which proved the point that on camera flash goes completely dumb with a dumb lens (and is the reason why I acquired triggers in retrospect)
The final shot in the set below was taken on my Q which does not support wireless flash. The setting was as above, except SL2
02-15-2016, 07:07 PM   #21
My posts (#4 and #8) in this thread explains the symptoms, including why there is sufficient light when the 540 is set at lower power ratio.
There is a very important detail but is still unknown: the OP has never replied whether his 540 is in SL1 or SL2 mode. I bet it is in SL2 mode.
OP, the simplest thing to check is set the camera at 2 sec timer. You'll see the pre-flash strobe from the built-in flash trigger the remote 540.
02-15-2016, 08:30 PM   #22
QuoteOriginally posted by SOldBear Quote
It's in SL2 which, as I understand it, is the only way to get it to work in fully manual mode?
Reading the linked thread this is the key bit of information:
"If you set the ratio of the remote flashes at 1/4 or lower, after they were triggered by the preflash strobe, there is sufficient charge left for them to fire when triggered AGAIN by the main strobe of the built-in flash, happening about 1/30 sec after the preflash strobe. At 1/2 and 1/1, the remaining charge is not enough for them to fire after the first time."
That makes perfect sense!
02-15-2016, 08:39 PM   #23
That's not correct.
I tested just now with Pentax 540 (Mk I), K-3, and K-7. 540 was in SL1. It was triggered by the main strobe, NOT by the pre-flash strobe from the camera's built-in flash. I tested the flash in p-TTL, A, and M mode.
02-15-2016, 08:58 PM   #24
That's not correct.
I'll try it now!
UPDATE - works a charm on the 540 mk1, alas the old Jessops unit doesn't have any options for slave mode!
02-17-2016, 10:37 AM   #25
mcgregni's Avatar
This thread has been very informative, but it's thrown up some contradictory points about Pentax wireless Manual flash mode. It's not a mode I tend to use, preferring wireless P-TTL generally, so I also have run a few tests using the K7 and AF-540FG.
Firstly just to clarify, and as others have also said, we DO have full Manual flash exposure control on the Pentax flashes wirelessly, and when using the camera built-in flash (those that support the wireless system). The flash must be set to wireless plus M mode, and the camera set to wireless flash mode. Flash compensation on the cameras has no effect (it only applies to P-TTL). The camera flash can be set to either ' master or control triggering mode. The flash power is directly controlled from the slave flash itself.
As we have already been told here earlier, for the built-in flash as trigger this uses the P-TTL optical communication and sends out mode information in the pre-flash, so the slave mode on the flash should be SL1 ( same as for P-TTL wireless).
The SL2 mode is for using the Pentax flash as a 'dumb slave' when triggered by any other manual flash when there is no pre-flash involved.
Finally I switched to SL2 mode and I experienced much the same as the OP .... The flash fired but did not illuminate the scene during the exposure at higher powers. It did however sync with the exposures at low powers, 1/32nd and 1/64th.
Thanks to the OP and everyone here for bringing this question forward ..... It is something that I will address more specifically in the next version of the Pentax Flash Guide.
af540, ambient, background, cactus, camera, camera flash, command, exposure, flash, image, k-5ii, k5ii, k5ii off camera, lighting, manual flash, off camera flash, photo studio, pm, post, power, pre-flash, results, shutter, strobist, subject
Using off camera flash trishytee Flashes, Lighting, and Studio 17 02-03-2016 02:33 PM
off camera flash on 645z gavincato Pentax Medium Format 12 07-27-2015 06:44 AM
Cheap vs expensive non-TTL off-camera flash PentaxLearner Flashes, Lighting, and Studio 18 03-31-2012 05:22 AM
Tips for using non-ttl flash off camera F8&Bthere Photographic Technique 15 08-16-2009 06:04 AM
HSS with a non P-TTL Flash off camera? Not Registered Flashes, Lighting, and Studio 13 12-05-2007 12:12 PM
All times are GMT -7. The time now is 09:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
