03-21-2016, 03:14 PM   #1
mattt's Avatar
firing 360 / 540 fgz faster than 1/180
Anyone tried to see if its possible using fancy flash triggers to make these faster?
03-21-2016, 03:21 PM   #2
Don't they support HSS out of the box? And 1/200s with the K-1?
03-21-2016, 03:31 PM   #3
mattt's Avatar
I was thinking more about using a trigger connected to a leaf shutter lens type fast.
03-21-2016, 03:51 PM   #4
In case of leaf shutter you don't need HSS - it can sync with any regular flash up to 1/400s or even 1/800s, depending on lens. BTW: are there any K-mount lens with leaf shutter?
03-21-2016, 03:52 PM   #5
mattt's Avatar
Im playing with 6x7 equipment.
03-21-2016, 04:23 PM   #6
It explains where you've found mysterious "K-mount" leaf shutter lens Simple setup like PC to hot shoe cable coupled with Yongnuo trigger and flash should do the trick. Alternatively, you may want to try F5P cable with adapter and off-camera 540FGZ. I have tried both Yongnuo and 360/540FGZ, and the former is better in some scenarios - for instance when slave flash 'can't see' master one.
03-22-2016, 01:45 AM   #7
clackers's Avatar
An Acon R930 controller will get you 1/8000s if you like by using HSS.
03-25-2016, 05:50 AM   #8
mattt's Avatar
I was using a Cactus V6 - and it appears the flash is firing fine, but there is some other issue with the equipment as the focal plane does not appear to be syncronized with the leaf shutter. Disregard the EXIF info for the bottom row of images, they were all 1/500 - annotation error.
Any way, thanks for the responses fella's
flash, lighting, photo studio, strobist
US Pentax Flash price drops (AF 360/540 FGZ II) Adam Pentax Price Watch 2 04-27-2015 09:33 AM
For Sale - Sold: DA* 50-135, DA 55-300, AF-540 FGZ, AF-360 FGZ II Flash apisto Sold Items 16 11-24-2014 07:14 AM
So what are my options for a flash that will shoot faster than 1/180? TimKierath Flashes, Lighting, and Studio 48 08-07-2013 12:27 PM
K-x won't go faster than 1/180 mojoe_24 Troubleshooting and Beginner Help 4 03-11-2012 08:29 AM
AF 540 FGZ for wireless in concert with the AF 360 FGZ Ed in GA Pentax Camera and Field Accessories 10 05-08-2007 09:45 PM
All times are GMT -7. The time now is 10:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
