Originally posted by disord3r The only problem with rechargeables is that the voltage starts out low compared to akaline batteries (1.2v vs. 1.5v).
I suspect flashes are rather tolerant of voltage differences compared to other things. One of the reasons the Eneloops got so popular here was that at the time many rechargeables would not work well in the k-x. The camera had issues with a lot of batteries actually. But for some reason the Eneloops worked fine. Someone explained back then that they held their voltage profile better during discharge so even though they are 1.2 volt they were able to hold that voltage instead of dropping under load as other batteries, even 1.5 volt ones did.
It is possible other brands would now work as well since that was almost 6 years ago but at the time they were head and shoulders better than anything else. And I find it quite remarkable that though the camera is long gone the batteries are still working just fine.
When we were having battery issues with the k-x, summer of 2010 I believe, I bought six sets of rechargeables, all different brands. Most lasted no more than a year or so, one set called Energyon finally died last year and another set branded Powerex lasted almost as long. But the Eneloops bought then are still taking and holding a charge. They might not last as long as they once did but since they are on flash duty now it is hard to compare.
