04-04-2016, 07:34 AM   #1
Nass's Avatar
Taping up everything except centre pin - safe?
Hello,
For various reasons I'm after a flash that has centre pin contact only. I don't have such a thing, but I do have an older flash (safe voltage) that I'd consider as expendable if this procedure cooked a flash.
Does anyone have experience covering everything except the centre pin with non conducting tape, and does doing this cook the camera or the flash? Ie is it safe to do??...
Thanks,
-Nass
04-04-2016, 07:41 AM   #2
Otis Memorial Pentaxian
It should be safe, how about just putting a "safe sync" in between. That will accomplish the same thing, but with less goo.
04-04-2016, 07:48 AM   #3
Nass's Avatar
Good shout, thanks. I assume 3rd party rather than Wein is ok - the Wein ones cost £33 in the UK but £66 postage from US!!
05-17-2017, 12:02 AM   #4
FilmORbitz's Avatar
QuoteOriginally posted by Nass Quote
Be careful of flash voltage limiters other than Wein Safe-Sync, which is rated for 400V max. Some of the other limiters (Vello at B&H for example) only have 60V ratings. I have a Metz 45 CT-1 that measures 325V, and some of the old Vivitar 2xx-series are over 200V. What isn't clear is whether the lower-rated devices are fail-safe. You don't want to do that test....
05-18-2017, 03:38 PM   #5
Class A's Avatar
How much is a Cactus V5 in your area these days?
It also provides a Wein-safe functionality (as a side-effect) and is rated up to 300V.
05-18-2017, 11:22 PM   #6
Nass's Avatar
About £55/£60 ish
05-19-2017, 12:55 AM   #7
Not a Number's Avatar
The spacing is different on the pins for Minolta flashes and only the center pin makes contact on a Pentax body. That's why "universal" off camera cables have so 6 or 7 contacts on them. No need to tape the pins off if that is the case.
I don't know about the spacing on flashes for Nikon, Canon or Olympus as I don't have any flashes for them.
05-19-2017, 06:16 PM   #8
I'm a "junk collector" when it comes to flash guns. I currently have no less than 2 dozens of them.
I've used my Pentax bodies (K10D, K-7, K-3) with flashes dedicated to Olympus, Minolta, Canon, Nikon, Leica, and of course Pentax without any problem.
No need to tape anything.
Of course the trigger voltage needs to be safe (to me, that means "under 24V").
05-22-2017, 03:52 AM   #9
Class A's Avatar
About £55/£60 ish
Too bad, I was hoping the price would be nearer the Wein-safe.
Your price is probably for a Duo set and you'd only need one of them for your purposes.
I didn't question your initial request because you seemed to know what you are doing, but I support the view of SOldBear that maybe you won't need any tweaking at all. Normally, the extra pins don't cause any trouble.
05-22-2017, 09:33 AM   #10
There's a paper out there somewhere that reverse engineered the pin out of Minolta X cameras (X-700 etc.). As I recall the voltages where on the order of 3-5 volts. One of the signals originates from the camera body.
I tend to agree with SOldBear also and don't think it is a problem.
centre, centre pin, flash, lighting, photo studio, pin, strobist
People Patricia Pin-up Michu Photo Critique 7 08-21-2012 06:50 PM
Macro Gazania centre up close eaglem Post Your Photos! 2 08-16-2012 07:49 AM
Nature Pin Up Girl (Work Safe) Rupert Post Your Photos! 4 08-02-2011 06:26 PM
Not Work-Safe Felicia - Pin Up. Ed n Georgia Post Your Photos! 8 08-01-2011 07:50 AM
Not Work-Safe Some Pin Up Metalwizards Photo Critique 6 05-09-2011 08:52 PM
All times are GMT -7. The time now is 01:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
